disable cli write-permission
Description
Disables access to the full CLI on 4120 Series and 4220 Series switches.
Syntax Description
N/A.
Default
N/A.
Usage Guidelines
Use this command to disable access to the full CLI on 4120 Series and 4220 Series switches.
The following command disables access to the full CLI:
This command was first available in Switch Engine 32.7.1.
Platform Availability
This command is available the 4120 Series and 4220 Series platforms are running Switch Engine.
